Use the Probe Points tool to define a point or set of points at specific co-ordinates
and probe/query results. This is useful for verifying experimental results with simulation
result.
From the Post ribbon, click the Probe Points tool.
The Probe locations dialog opens.
Define probe points in the following ways:
- Click directly in the modeling window to create
points and populate coordinates.
- Click
in the dialog to add a new probe point then
manually define the coordinates.
- Click
in the dialog, select a probe point, then use
the manipulators to adjust its position.
Tip: Click
to import or export a probe point coordinates file.
Click Calculate on the guide bar
to extract values.
A new Point Probe entity is added to the
Post Browser,
A table with extracted values for all variables is populated. This
data can be saved to a text file.
On the guide bar, click
to confirm your selection and remain in
the tool or click
to confirm your selection and exit the
tool.
