Use the Calculate tool to define a derived variable as a function of existing
variables.
From the Post ribbon, click the Calculate tool.
The Derived Data Calculator dialog
opens.
Click
to add a variable.
Define the name and expression.
- Define the name without spaces so that it can be utilized in further
expression definitions.
- If using an existing variable with a space in its names, like “wall
shear stress”, replace the spaces with “_”.
- Expressions are defined in python syntax.
Tip: Click
to import or export defined
expressions.
Once derived variables are defined, they are available for
contours and probes or integration
