Compare HG Version Results
The Result comparison HG versions tab performs time history comparison. From this tab, you can perform the curve's super positioning of the current and reference version result files and plot the differences in curves.
  1. Click the Result tab then the Result comparison HG versions tab.
  2. Select the current and reference solver version.
  3. Choose between a PowerPoint or HTML report of the result value comparison.
  4. Load the data file.
  5. Select an output directory.
  6. Click Apply to extract information from the data file.
    Tip: Click Extract to extract and compare TRCs in the Current and Reference versions.
  7. Select a subcase from the drop-down menu.
  8. Select an X type from the drop-down menu.
    Tip: Activate the Plot only failed checkbox to only plot failed graphs.
  9. Select any combination of Y Type, Y Request, and Y Component values from the populated areas.
    Click All to select all items listed.
  10. Click Apply to generate TH plots with the selected Y Type, Y Request, and Y Component.
    The Compare result section displays the current file and the corresponding reference file. Click Report to display the diff report detailing the differences between files.
Tip:
  • Click Messages to view any error messages.
  • Click Html Report to generate an HTML report of your session information for any number of files run through the process.
