Compare HG Solver Version Results
The Solver version result comparison HG tab performs time history comparisons. From this tab, you can perform the curve super positioning of the current and reference version result files and plot the differences in curves.
  1. Click the Solution tab then the Solver version result comparison HG tab.
  2. Select Radioss or OptiStruct as the solver type from the drop-down menu.
  3. Select the current HyperWorks version from the Version drop-down menu.
  4. Choose between a PowerPoint or HTML report of the result value comparison.
  5. Select the current and reference data file.
  6. Select an output directory.
  7. Click Apply to extract TRC information from the data file.
  8. Select a subcase from the drop-down menu.
  9. Select an X type from the drop-down menu.
  10. Optional: Activate Plot only failed to plot only failed graphs.
  11. Select any combination of Y Type, Y Request, and Y Component values from the populated areas.
    Click All to select all items listed.
  12. Click Apply to generate TH plots with the selected Y Type, Y Request, and Y Component.
    The Compare result section displays the current file and the corresponding reference file. Click Report to display the diff report detailing the differences between files.
Tip:
  • Click Messages to view any error messages.
  • Click Html Report to generate an HTML report of your session information for any number of files run through the process.
