Launching OPTFEKO (Linux)
Use the most suitable option for launching OPTFEKO in Linux.
Launch OPTFEKO using one of the following options:
  • On the Solve/Run tab, in the Run/Launch group, click the  OPTFEKO icon.
  • Launch OPTFEKO from the command line in a terminal environment.
    1. Open a command terminal. Source the script “initfeko” using the absolute path to . /home/user/2021/altair/feko/bin/optfeko
    2. In the terminal (assuming the model with file name dipole.cfx is to be optimised) type the following command
      optfeko dipole
      and press Enter.
    Note: The above steps will launch OPTFEKO without any special settings. It is also possible to use parallel processing for optimisation.
