Defining an Optimisation Goal
An optimisation goal defines the solution request type to be optimised and the goal it will attempt to achieve.
To define an optimisation goal, you first need a defined optimisation search.
  1. In the model tree under Optimisation, select a search for which you want to add a optimisation goal.
  2. On the Request tab, in the Optimisation group, click the  Add goal function icon.
  3. From the drop-down list, select one of the following:
    • Impedance goal
    • Near field goal
    • Far field goal
    • Power goal
    • Receiving antenna goal
    • S-matrix goal
    • Transmission/reflection coefficients goal
    • SAR goal
