Completing the Model
Complete the model construction in CADFEKO.
- Create the ground plane rectangle at Z = -0.508.
- Add a line between the feed pad and the ground plane.
- Add a wire port to the line.
- Create the vias using lines and Copy special and translate.
- Delete the redundant polylines.
- Union the remaining geometry.
- From the Media library add Copper to the model.
- Change all the PEC faces to Copper with thickness 35e-3.
Add a new dielectric medium:
- Relative permittivity: 3.55
- Dielectric loss tangent: 0.003
- Label: Substrate
Add a Planar multilayer substrate.
- Thickness (Layer 1): 0.508
- Medium (Layer 1): substrate
Set a continuous frequency range from 1 GHz to 3 GHz.
On the Export tab check the box Specify number of samples for exported data and enter a value of 101.
