Observe the effect of an obstacle on a plane wave. Obtain frequency domain results using a wideband simulation using
the method of moments (MoM). Perform post-processing of the frequency domain data to obtain a time response.
Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO
(large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
A simple example demonstrating the time analysis of an incident plane wave on an
obstacle.
Effect of Incident Plane Wave on an Obstacle Using Time Analysis
Observe the effect of an obstacle on a plane wave. Obtain frequency domain results using a wideband simulation using the method of moments (MoM). Perform post-processing of the frequency domain data to obtain a time response.
