Defining Calculation Requests
Define the calculation requests in CADFEKO.
  1. Create a vertical far field request (-180°θ≤180°, with ϕ=0°). Sample the far field at θ=1° steps.
  2. Request the far field calculation for an array of 10x10 elements.
      Tip: Open the Request/Modify far fields dialog, click the Advanced tab and then click the Calculate far field for an array of elements check box.
