Application Launcher
The application launcher toolbar is a small toolbar that provides quick access to other Feko components.
EDITFEKO is a scripting interface for advanced users to construct models using a high-level scripting language, which includes FOR loops and conditional IF-ELSE statements.
View the main elements and terminology in the EDITFEKO graphical user interface (GUI).
The quick access toolbar is a small toolbar that gives quick access to actions that are often performed.
The ribbon is a command bar that groups similar actions in a series of tabs.
The editor area allows you to edit .pre files. The script editor includes syntax highlighting and each file is contained in its own tab.
Press F1 on a card to highlight the card entry in the editor area and display the full card definition in the card panel.
The status bar is a small toolbar that shows the line and column number for the current cursor position as well as the setting for the text editor (insert or overwrite).
The card panel contains the full card definition and provides editing of the card parameters.
The Help icon provides access to the Feko documentation.
The search bar is a single-line text field that allows you to enter search terms and find relevant information in the GUI or the documentation.
The application menu is similar to a standard file menu of an application. It allows saving and loading of models, print functionality and gives access to application-wide settings.
The language used to create and modify models in EDITFEKO is the PREFEKO language.
Create geometry in EDITFEKO according to the guidelines to ensure that different mesh parts are electrically connected. Meshes can also be imported to create a model.
EDITFEKO has various default settings that you can configure to customise it to your preference.
View the files associated and generated by EDITFEKO.
View the shortcut keys available for EDITFEKO for faster and easier operation of EDITFEKO.
ON THIS PAGE
ON THIS PAGE
