Script Editor Area
The editor area allows you to edit .pre files. The script editor includes syntax highlighting and each file is contained in its own tab.
- Re-order the window tabs by simply dragging the tab to the desired location.
- View the path to the open .pre file by hovering with mouse cursor over the window tab.
- Drag-and-drop functionality is supported.
The editing tools are available on the Home tab, in the Edit group.
| Icon | Icon text | Description |
| Copy | Copy the selected text to clipboard. Shortcut: Ctrl+C | |
| Cut | Cut the selected text to clipboard. Shortcut: Ctrl+X | |
| Paste | Paste the text from clipboard. Shortcut: Ctr+V | |
| Comment | Block comment the selected items. Shortcut: Alt+C | |
| Uncomment | Uncomment the selected items. Shortcut: Alt+U | |
| Find / Replace | A find and replace tool with the following text search functionality: Find next, Find previous, Replace, Replace all, Close. Shortcut: Ctrl+F | |
| Goto line | A tool which allows you to find a specific line in the script. This is useful when PREFEKO reports an error with a corresponding line number. |
