Altair Feko  2021 Documentation
  1. Home
  2. EDITFEKO
  3. Quick Tour of the EDITFEKO Interface
    View the main elements and terminology in the EDITFEKO graphical user interface (GUI).
  • Release Notes
  • Get Started
  • Examples
  • Introduction to Feko
  • CADFEKO
  • POSTFEKO
  • EDITFEKO
  • Feko Solution Methods
  • Optimisation in Feko
  • Feko Utilities
  • Description of the Output File of Feko
  • Feko Application Macros
  • Scripts and Application Programming Interface (API)
  • Appendix
Index
  • Release Notes
  • Get Started
  • Examples
  • CADFEKO
  • POSTFEKO
  • EDITFEKO
    • Introduction to EDITFEKO
      EDITFEKO is a scripting interface for advanced users to construct models using a high-level scripting language, which includes FOR loops and conditional IF-ELSE statements.
    • Quick Tour of the EDITFEKO Interface
      • Quick Access Toolbar
        The quick access toolbar is a small toolbar that gives quick access to actions that are often performed.
      • Ribbon
        The ribbon is a command bar that groups similar actions in a series of tabs.
      • Script Editor Area
        The editor area allows you to edit .pre files. The script editor includes syntax highlighting and each file is contained in its own tab.
      • Edit Card
        Press F1 on a card to highlight the card entry in the editor area and display the full card definition in the card panel.
      • Status Bar
        The status bar is a small toolbar that shows the line and column number for the current cursor position as well as the setting for the text editor (insert or overwrite).
      • Card Panel
        The card panel contains the full card definition and provides editing of the card parameters.
      • Help
        The Help icon provides access to the Feko documentation.
      • Search Bar
        The search bar is a single-line text field that allows you to enter search terms and find relevant information in the GUI or the documentation.
      • Application Launcher
        The application launcher toolbar is a small toolbar that provides quick access to other Feko components.
      • Application Menu
        The application menu is similar to a standard file menu of an application. It allows saving and loading of models, print functionality and gives access to application-wide settings.
    • PREFEKO Language Concepts
      The language used to create and modify models in EDITFEKO is the PREFEKO language.
    • Creating Geometry in EDITFEKO
      Create geometry in EDITFEKO according to the guidelines to ensure that different mesh parts are electrically connected. Meshes can also be imported to create a model.
    • Preferences
      EDITFEKO has various default settings that you can configure to customise it to your preference.
    • Files Generated by EDITFEKO
      View the files associated and generated by EDITFEKO.
    • Shortcut Keys
      View the shortcut keys available for EDITFEKO for faster and easier operation of EDITFEKO.
  • Feko Utilities
  • Appendix
  1. Home
  2. EDITFEKO
  • Release Notes
  • Get Started
  • Examples
  • CADFEKO
  • POSTFEKO
  • EDITFEKO
  • Feko Utilities
  • Appendix
Index
Figure 1. The EDITFEKO window.
  1. Quick Access Toolbar
  2. Ribbon
  3. Script Editor Area
  4. Edit Card
  5. Status Bar
  6. Card Panel
  7. Help
  8. Search Bar
  9. Application Launcher
  10. Application Menu
  • Ribbon
  • Edit Card
  • Status Bar
  • Card Panel
  • Help
  • Search Bar
  • Application Menu
