Doppler Analysis
Doppler analysis is mainly used to obtain insight in the results of automotive radar simulations, where Doppler shift is critical in subsequent signal processing.
Doppler Shift / Doppler Shift (3D)
- In the results tree, select Power (MS) or Power. These are the power received by the receiver antenna and the power received by a hypothetical isotropic antenna, respectively.
- Select the time step of interest (if it was a time-variant simulation).
- Click
- Doppler Shift
- Hover the cursor over the result pixel of interest for
Doppler shift.
Figure 1. A graph showing for all contributing rays the Doppler shift along the horizontal axis and the power along the vertical axis.
Doppler shift.
- Doppler Shift (3D)
- Click on the pixel of interest. In an automotive radar
simulation, there is often just one result pixel, located at
the radar position.Tip: Zoom in if needed to view the result pixel.
Figure 2. A 3D plot showing for all contributing rays the Doppler shift and the signal delay along the two horizontal axes and the power along the vertical axis.
the radar position.
and select one of the following: - Doppler Shift
Doppler Heat Map
- Click .
- Click on the radar pixel to generate the heat map.
- [Optional] Activate/deactivate the legend on the plot by right-clicking on the plot and click Display Legend check box. and select/clear the
Figure 3. A heat map for the radar channel profile with range and velocity along the axes.
