Propagation Models
For the installation of mobile radio systems, wave propagation models are necessary to determine propagation characteristics for any arbitrary configuration. The predictions are required for a proper coverage planning, the determination of multipath effects as well as for interference and cell calculations, which are the basis for the high-level network planning process.
For the wave propagation prediction of leaky feeder cables special models are used, which can be specified and parameterized on the Computation tab.
The phenomena which influence radio wave propagation can generally be described by four basic mechanisms: Reflection, diffraction, penetration and scattering. For the practical usage of propagation models in real scenarios these mechanisms must be described by approximations.
The basis for any propagation model is a data base which describes the propagation environment. Considering indoor propagation suggests, for the purpose of propagation modeling, that each building element should be categorized into classes (wall, floor, door, window) and specified by its coordinates and finally its material properties (thickness, permittivity, conductivity).
