Mast
- Cylinder with a circular cross-section
- Diameter of the cross-section (user defined)
- Height of the mast (user defined)
- Material properties (reflection and transmission loss) (user defined)
- Smooth surface (only specular reflection, no scattering)
As the mast is a cylinder with a circular cross-section, the information related to circular objects also applies to the mast.
