Specifying the Computation Method
Select the COST 231 - extended Walfisch-Ikegami model as computation method.
  1. Click the Computation tab.
  2. Under Prediction model (Urban), click Empirical Vertical Plane Model: COST 231: Extended Walfisch-Ikegami-Model.
  3. Under Indoor Prediction, select the Indoor Coverage (without indoor walls) check box.
  4. Click OK to close the Edit Project Parameter dialog.
