In an urban scenario, antennas are usually placed at the top of a building. When defining an antenna site, you require
the height of the building to ensure that the antenna is placed above the building not inside.
WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications
ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning
to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output
(MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine
the actual antenna pattern while taking into consideration the local environment.
WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models
as well as the unique dominant path model (DPM).
In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks,
ICNIRP and EM compliance.
defining an antenna site, you require the height of the building to ensure that the antenna
Determine the height of a specific building using one of the following
workflows:
On the Display menu, click
Balloon Tips.
On the Utility toolbar, click the
Balloon tip icon.
The mouse cursor changes from a “+” to an “X”.
Hover with the mouse over a building to view the building height in a balloon
tip.
