Setting Up the Simulation in ProMan
Set up the propagation simulation parameters. Solve the urban database and inspect the coverage plots.
The base stations set in an urban environment, is solved using the following two methods: the dominant path model and COST 231 - extended Walfisch-Ikegami model.
