Submit Jobs
Use the Run VWT tool to specify the simulation time for a transient run and other setup parameters, as well as submit the actual analysis.
Visualize Results
Use the Show Analysis Results tool to open a results file in AcuFieldView.
Plot Aero Coefficients
Use the Plot Aero Coefficients tool to generate a 2D graph of the lift, drag, and side forces acting on the body in the wind tunnel.
