Build Block Diagram
Build the Block Diagram presenting the process in the form of a flow chart.
- From the Library Browser, Solution Template folder, select the Solution - High Frequency EM1 file and drag it into the Block Diagram.
From the Application Mapping dialog, select the
application CADFeko 2021.1.
Figure 1. - From the Conversion folder, drag and drop the Powerloss to Heat file into the Block Diagram.
- From the Application Mapping dialog, select the application ComposeBatch 2021.2.
In the Block Diagram, connect the Solution - High Frequency EM1 outputs to the
Powerloss to Heat inputs.
Figure 2. - From the Library Browser, Solution Template folder, drag and drop the Solution - Thermo-Mechanical2 file into the Block Diagram.
- From the Application Mapping dialog, select the applications Hypermesh Batch 2021.2 and OptiStruct Solver 2021.2.
In the Block Diagram, connect the Powerloss to Heat outputs to the Solution -
Thermo-Mechanical2 inputs.
Figure 3. -
Launch Task.
From the Author ribbon, Create group, click the Launch
Task tool.
Figure 4.The Entity Editor opens. - In the Entity Editor, enter View Results as the task name.
Click in the Application field, and select
from the drop-down menu.
In the Advanced Selection dialog, select
HyperWorks HV as the Application and click
OK.
Figure 5. -
In the Entity Editor, enter -f
$ALTAIR_PULSE_WORKDIR/MyOSStep5.h3d for the Argument and
click Close.
Figure 6.
Task tool.
In the Block Diagram, right-click the Output port for View Results and select
Delete from the context menu.
Figure 7. -
Connect the Thermo-Mechanical2 output to the View Results input.
Figure 8. -
From the Author ribbon, Execute Process group, click the
Run tool.
Figure 9.The simulation begins to run and the Entity Editor opens. -
In the Entity Editor, click
Close.
Figure 10.
