Time Series Scatter Plot Settings
These are divided into four tabs:
General
Setting
Min Radius
The minimum radius in pixels of the scatter point.
Max Radius
The maximum radius in pixels of the scatter point.
Show Circle Borders
Determines whether a border is drawn around each scatter point.
Shape
The shape of the scatter point. This can be:
Filled Circle
Circle
Filled Square
Square
Use Variable - shapes can be specified for the elements in the visualization through the Shape variable
Axes
Refer to Cross Tab Axes, Visualizations Axes, and Time Axes for more information.
Synchronization
Filters
Refer to Visualization Static Filter for more information.
