Cross Tab Axes
Visualizations that support cross tabbing include the following settings for both the X and Y axes.
Setting |
Description |
Leaf Bar Thickness |
The width or height allocated to last component of the cross tab axis in pixels. |
Leaf Label Angle |
The angle of text of the last component of the cross tab axis. |
Inner Bar Thickness |
The width or height allocated to all of the other components of the cross tab axis in pixels. |
Inner Label Angle |
The angle of text to all of the other component of the cross tab axis. |
Min Interval Length |
The minimal interval in pixels between crosses tabbed visualizations. |
Max Interval Length |
The maximum interval in pixels between crosses tabbed visualizations. |
Word Wrap |
Determines whether to wrap the cross tab axis text. |
Show All Column Levels |
Determines whether space in the text axis should be allocated to all hierarchy levels, and whether visible or not. |
