Visualization Static Filter
You can define a filter to a visualization based on a specific subset of the available data set.
Defining Visualization Static Filter
Select the Filters tab of a visualization and click Add.
Click the Column drop-down and select a dimension.
Enter a Value.
NOTE: You can add more than one value for a Column. For example:
You can also opt to select a set parameter value in the Parameter drop-down list.
This will overwrite the entered filter values.
Click Add to add more filters.
Click
to delete a visualization
filter definition.
Click Close to save the changes and apply the filter.
