Spread Graph Settings
These are divided into four tabs:
General
Setting
Line Width
Specifies the width in pixels of the Spread Graph data series lines.
Line Interpolation Mode
Specifies the interpolation mode as either Linear or Stepped.
Interpolate Across Time Axis Gaps
Determines whether to interpolate across weekend and closed period gaps.
Interpolate Across Na Value Gaps
Determines whether Na value (or missing) gaps are interpolated.
Value Line Color
Specifies the color of the value line data series.
Reference Line Color
Specifies the color of the reference line data series.
Positive Spread Color
Specifies the color when the spread between the value and reference is positive.
Negative Spread Color
Specifies the color when the spread between the value and reference is negative.
Spread Color Alpha
Specifies the level of color transparency/opacity for the Positive and Negative Spread colors. The value is from 0 to 255 with the default set to 128.
Axes
Refer to Cross Tab Axes, Visualizations Axes, and Time Axes for more information.
Synchronization
Filters
Refer to Visualization Static Filter for more information.
