Price Band Settings
These are divided into four tabs:
General
Setting
Line Interpolation Mode
Specifies whether the line is Stepped, or a Linear Interpolation.
Interpolate Across Time Axis Gaps
Determines whether time axis gaps (Working Week/Time) are interpolated.
Interpolate Across Na Value Gaps
Determines whether Na value (or missing) gaps are interpolated.
Spread Color Alpha
Specifies the level of color transparency/opacity for the Positive and Negative Spread colors. The value is from 0 to 255 with the default set to 128.
Line Width
Select the line width (in pixels).
Axes
Refer to Cross Tab Axes, Visualizations Axes, and Time Axes for more information.
Synchronization
Filters
Refer to Visualization Static Filter for more information.
