Needle Graph ( Standard, Stacked & Grouped) Settings
These are divided into four tabs:
General
Setting
Needle Width
Specifies the width in pixels for each needle:
Set Needle Width to Time Slice
Determines whether the Needle width will be extended to the width of the time slice.
NOTE: Will not go past a null/empty time slice.
Show Borders Around Needles
Specifies whether a border is drawn around needles. These are only visible if the Needle Width is greater than 1 pixel.
Axes
Refer to Cross Tab Axes, Visualizations Axes, and Time Axes for more information.
Synchronization
Filters
Refer to Visualization Static Filter for more information.
