Example 4: Coupling
This case explains how to calculate the coupling between two antennas.
Step 1
Start newFASANT and select GTD-PO.
Figure 1. Method type selection.
Step 2
Define the geometry of an ellipsoid
Figure 2. Ellipsoid command.
Step 3
Click on Simulation -> Parameters to change the project parameters
Figure 3. Simulation parameters panel.
Step 4
Click on Source -> Parameters to modify the source parameters for this project
Figure 4. Source parameters panel.
Step 5
Click on Output -> Coupling to define the parameters of the passive source
Figure 5. Coupling parameters panel.
Step 6
Before running this example, create the project mesh by doing click on Meshing -> Create Mesh
Figure 6. Mesh result.
Step 7
Now we are going to proceed to simulate the project.
Click on Calculate -> Execute and choose the number of processors to use for the simulation. Then click on the Execute button and wait until it ends.
Step 8
Now you can see the results of the simulation by doing click on Show Results -> Coupling -> Source Coupling.
Figure 7. Coupling results.
