newFASANT 2021.2 Documentation
  1. Home
  2. GTD-PO
    GTD-PO combines the GTD and PO high-frequency techniques for the RCS analysis of complex bodies as well as antenna and radio propagation in large urban environments.
  3. Meshing Menu
  • Release Notes
  • Get Started
  • Examples
  • Utilities
  • GUI
  • Post-Process
  • Antennas
  • Materials
  • Command Line
  • GTD
  • PO
  • GTD-PO
  • MONCROS
  • MOM
  • Periodical Structures
  • Parabolic Equation
  • Ultrasound
  • List of Acronyms and Abbreviations
Index
  • Release Notes
  • Get Started
    The newFASANT User Guide contains examples with step-by-step instructions on how to get started with newFASANT.
  • Examples
    The newFASANT User Guide contains a collection of examples that teaches you newFASANT concepts and essentials.
  • Utilities
    The newFASANT utilities allows you to set up a remote server, use the batch utility to mesh and execute a project or upload a project to a queueing system.
  • GUI
    An overview of the newFASANT graphical user interface is given.
  • Post-Process
    Results can be post-processed to obtain customized results.
  • Antennas
    A large collection of antennas are supported as well as importing radiation patterns and specifying the antenna feeding.
  • Materials
    Materials can be defined, edited, deleted and assigned to specific surfaces or objects.
  • Command Line
    The command line can be used to draw geometries or change the GUI configuration.
  • GTD
    GTD can be used for 3D analysis of on board antennas and coverage parameters for radiocommunications systems.
  • PO
    PO is used for radar cross section analysis of electrically large and complex targets using physical optics (PO).
  • GTD-PO
    • File Menu
    • Edit Menu
    • View Menu
    • Geometry Menu
    • Materials Menu
    • Simulation Menu
    • RCS Menu
    • Source Menu
    • Output Menu (Alt +O)
    • Meshing Menu
      • Create Mesh
      • Visualize Existing Mesh
      • Manual Surface Classification
      • Manual Divisions
    • Calculate Menu (Alt + C)
    • Show Results Menu
    • Tools Menu
    • Help Menu
    • Training Examples
  • MONCROS
    MONCROS is used for 3D radar cross section (RCS) using the method of moments (MOM) technique.
  • MOM
    MOM is used for the 3D analysis of complex antennas, on board antennas, electromagnetic compatibility and radar cross section (RCS).
    Periodical structures is used for the analysis and design of reflection and transmission coefficients in periodical structures and metamaterials.
    PE is used for the analysis of radio-wave propagation over land and sea for medium and large distances.
  • Ultrasound
    Ultrasound is used for the 3D analysis of ultrasound emitting sources and time delay response simulation.
    View the list of commonly used acronyms in newFASANT.
  1. Home
  2. GTD-PO
  3. Meshing Menu
  • Release Notes
  • Get Started
  • Examples
  • Utilities
  • GUI
  • Post-Process
  • Antennas
  • Materials
  • Command Line
  • GTD
  • PO
  • GTD-PO
  • MONCROS
  • MOM
  • Ultrasound
Index
Meshing Menu
Figure 1. Meshing Menu
  • Create Mesh
  • Manual Divisions
