Calculate Menu (Alt + C)
![](../../../../images/newfasant/gtd_po/calculate_menu_alt_c/image20170118-8746-1tofgj8.png)
Figure 1. Calculate Menu
Before executing the simulation the user needs to make sure that every simulation parameter has been correctly configured. If something is wrong with a user defined parameter a warning message is displayed to let the user know that it is necessary to correct one or more parameters.
