Example 2: Monostatic RCS of a Ship
This case explains how to calculate the monostatic RCS of an imported geometry.
Step 1
Start newFASANT.
Step 2
Select File and click on New.
Step 3
Select GTD-PO.
![](../../../../images/newfasant/image_new_project.png)
Figure 1. Method Type selection
Step 4
Select the geometry to import.
![](../../../../images/newfasant/gtd_po/training_examples/import.png)
Figure 2. Import geometry menu
Step 5
Click on Simulation -> Parameters to change the project parameters.
![](../../../../images/newfasant/gtd_po/training_examples/15_2_GTD-PO_SimulationParameters.png)
Figure 3. Simulation parameters window
Step 6
Click con RCS -> Parameters to set de RCS parameters of the project.
Figure 4. RCS parameters window
Step 7
Click on Source -> Parameters to modify the source parameters for this project.
![](../../../../images/newfasant/gtd_po/training_examples/source_2115.png)
Figure 5. Source parameters panel
Step 8
Introduce the observation information as follows:
![](../../../../images/newfasant/gtd_po/training_examples/observation.png)
Step 9
Before running this example, create the project mesh by doing click on Meshing -> Create Mesh.
![](../../../../images/newfasant/gtd_po/training_examples/15_2_GTD-PO_Mesh.png)
Figure 6. Meshing panel
![](../../../../images/newfasant/gtd_po/training_examples/imag.png)
Figure 7. Meshing execution log
Step 10
Visualize the created mesh. To do this click on Meshing -> Visualize mesh.
Now you will be able to choose the generated mesh file.
Figure 8. Visualize generated mesh
Step 11
Now we are going to proceed to simulate the project.
Click on Calculate -> Execute and choose the number of processors to use for the simulation. Then click on the Execute button and wait until it ends.
![](../../../../images/newfasant/gtd_po/training_examples/simulation_log.png)
Figure 9. Simulation log
Step 12
Now you can see the results of the simulation by doing click on Show Results and selecting the desired results.
![](../../../../images/newfasant/gtd_po/training_examples/15_2_GTD-PO.png)
Figure 10. View RCS cut result
Figure 11. Ray tracing results
