Thicken a Solid Part
Create a hollow shell based on the dimensions of a selected solid part.
On the Geometry ribbon, select the
Offset tool.
- On the guide bar, select Thicken.
- Select a solid part.
In the microdialog, enter a value for the desired offset distance and select
additional options:
- To reverse the direction of the offset, select the
icon. - To apply the offset to both the inside and outside of the part's
surface, select the
icon. - To apply a variable to the offset field, select the
icon.
