Offset a Solid Part
Proportionally increase or decrease the size of a solid part, or create a proportionally larger or smaller new part.
On the Geometry ribbon, select the
Offset tool.
- On the guide bar, select Offset and Parts.
- Select the part.
In the microdialog, enter a value for the desired offset distance and select
additional options:
- To reverse the direction of the offset, select the
icon. - To create a new offset part and keep the original part, select the
icon. - To apply a variable to the offset field, select the
icon.
- Select Apply on the guide bar or microdialog.
Right-click and mouse through the check mark to exit, or double-right-click.
Note:
If you selected the
icon, the parts will occupy the same space
in the modeling window. Use the move tool to reveal the smaller part.
