Dynamic Friction Coefficient Exceeds Static Coefficient
Remedy
  • For rigid joints, change the static coefficient so it is greater than or equal to the dynamic coefficient under Friction Effect in the joint friction properties.
  • For motion contacts, change the static coefficient so it is greater than or equal to the dynamic coefficient on the motion contacts microdialog, table, or Property Editor.
