Force Vectors Are Unavailable
Condition
Entity buttons are missing on the Force Explorer.
Cause
The buttons are missing because either the Plots option has been set to None, or you are not using Global reference frame for plotting.
Remedy 1: Plots Are Turned Off
- Set Plots to All in the Advanced section of the Run Motion Analysis Settings.
- Rerun the analysis.
Remedy 2: Plots Are Not Global
- Set Plots to Global in the Advanced section of the Run Motion Analysis Settings.
