Motion Contact Force Results Not Found
Condition
Loads coming from motion contacts are missing. If you click the Continue button, the missing loads will not be applied to the part.
Cause 1
The Keep Force Results option was set to None in the Run Motion Analysis window.
Remedy
We recommend that you set the Keep Force Results option to All or Region Only when you intend to perform part anlysis or part optimization with motion loads.
Cause 2
While the Keep Force Results option was set to All or Region Only in the Run Motion Analysis window, this setting was overridden in the Property Editor for one or more motion contacts.
Remedy
Review the motion contacts for the part you want to analyze or optimize. We recommend that you check the Keep Force Results option in the Property Editor and if it set to None, change it to one of the other options such as Region Only.
