/MONVOL/AREA
Block Format Keyword Describes the monitored volume type AREA.
| /MONVOL/AREA/monvol_ID/unit_ID | |||||||||
| monvol_title | |||||||||
| surf_IDex | |||||||||
| Blank Format | |||||||||
| monvol_ID | Monitored volume
| unit_ID | Optional unit
| monvol_title | Monitored volume
| surf_IDex | External surface
identifier (Integer) |
- surf_IDex must be defined using segments associated with 4-nodes or 3-nodes shell elements (possibly void elements), and not with /SURF/SEG.
- The volume must be closed and the normals must be oriented outwards.
