/INTER/LAGMUL/TYPE2
Block Format Keyword Describes the Lagrange multiplier interface TYPE2.
- The incompatibility with standard kinematic conditions are checked out automatically in Starter
- Other Lagrange multiplier conditions may be applied to main and secondary nodes, unless there is a physical incompatibility
- There is no added mass on main node
- Kinematic conditions are applied to secondary and main nodes
| /INTER/LAGMUL/TYPE2/inter_ID/unit_ID | |||||||||
| inter_title | |||||||||
| grnd_IDs | surf_IDm | Isearch | dsearch | ||||||
| inter_ID | Interface
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| inter_title | Interface
title. (Character, maximum 100 characters) |
| grnd_IDs | Secondary nodes group
identifier. (Integer) |
| surf_IDm | Main surface
| Isearch | Search formulation flag
for the closest main segment.
(Integer) |
| dsearch | Distance for searching
closest main segment. Default is the average size of the main segments. (Real) |
- The dsearch is computed as:
(1)
