/GAUGE
Block Format Keyword Defines gauges.
| /GAUGE/gauge_ID/unit_ID | |||||||||
| gauge_title | |||||||||
| node_ID | shell_ID | DIST | |||||||
| gauge_ID | Gauge
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| gauge_title | Gauge title. (Character, maximum 100 characters) |
| node_ID | Node
identifier. (Integer) |
| shell_ID | Shell
| DIST | Distance between gauge and
shell surface.
Default = 0 (Real) |
- Pressure gauges can be defined by:
- A node using a node identifier (node_ID > 0), or
- A shell element (shell_ID) and a distance (DIST). In this case node_ID must be equal to 0.
- Pressure gauges have a few restrictions:
- Only 4-node shells can be used for shell_ID
- For Coupled Euler Lagrange interface only - shells (shell_ID) must be used with a distance (DIST) greater than interface TYPE18 gap
- For Finite Volume Method only - nodes (node_ID) must be used
