Sinusoidal vibration superimposed on random vibration.
A typical application for sine-on-random vibration is in aircrafts. During service,
an aircraft experiences random vibration. On top of the random vibration, sinusoidal
vibration at various frequencies come from turbine engines or rotor blades.
Components in the aircraft are expected to survive for certain life cycles under
sine-on-random vibration. This application is not limited to aircraft; any moving
machines which contain high-speed rotating parts may experience sine-on-random
vibration, regardless of severity.
Input loading for sine-on-random vibration is represented using a mixed mode: PSD of
random load and a certain amplitude of sine load.
Damage Calculation
Damage calculation due to sine-on-random vibration is a similar procedure to regular
random vibration fatigue (Refer to Random Response Fatigue Analysis). The difference due to the
superimposition of sine loads changes how the spectral moments are calculated.
The moments are calculated as:
(1)
Where,
- Frequency value.
- Stress PSD response value at frequency
- Number of frequencies in stress PSD.
- Number of frequencies of sine tones.
- Stress amplitude due to sine tone at the i-th frequency.
The second term is a contribution from sine tones. The recommended Probability
Density Function (PDF) to calculate number of cycles for sine-on-random is Dirlik.
Refer to Random Response Fatigue Analysis.
Input
A random response analysis and a frequency response analysis are underlying subcases
for sine-on-random fatigue. In a particular FATEVNT entry, a
FATLOAD referencing the random response analysis and another
FATLOAD referencing a frequency response analysis should be
specified to activate sine-on-random fatigue.
The FATLOAD data referencing the frequency response analysis
should also list frequencies (in Hz) and their amplitude factors in the
HARMO continuation line.
As an example, consider SUBCASE 10 is a random analysis subcase, and SUBCASE 20 is a
frequency response analysis subcase. The following setup showcases how
sine-on-random fatigue is
activated:
FATLOAD,100,,10
FATLOAD,200,,20
+,HARMO,1.0,0.1,15.0,1.0,20.0,1.1
FATEVNT,1000,100,200
Where the three sine tone frequency values are 1.0, 15.0, and 20.0; their
corresponding amplitude factors are 0.1, 1.0, and 1.1, respectively.
Output
General fatigue output for Damage and Life are supported. The damage output is
multiplied by exposed time T defined on the
FATSEQ Bulk Data Entry and reported.
