Supported Checks
Supported default checks organized by solver interface.
Use the Model tool to quickly run solver-related checks on all/selected entities in the model and apply auto-correction where defined.
Use the Model Checker to configure solver validity checks, modify and create new checks and corrections, and fix modeling issues in an automatic or manual way.
Provides a variety of options for working with the Model Checker.
Create new checks and corrections, and edit default checks and corrections.
Organize new and existing checks inside of a user-defined Check Folder.
Save configurations for future use, import existing configurations into your current HyperWorks session, or append configurations on top of existing configurations.
Find all entities in your model that failed the active checks in the Model Checker.
Use this sample script to run the Model Checker in batch mode.
ON THIS PAGE
ON THIS PAGE
