Reference Browser
The Reference Browser enables you to quickly understand complex relationships between different entities that constitute the model.
To open the Reference Browser, select an entity, then right-click and select References from the context menu menu.
Restriction: The Reference Browser is only available in HyperMesh.
To navigate and understand the relationships between the different entities, double-click on an entity to trigger a cross referencing operation.
Cross referencing operations are recorded in the Reference Browser. To navigate between cross referenced states, click the forward and back buttons in the top, left corner of the browser.
