Aerospace 2021.2 Release Notes
Highlights
- Starting with the 2021.2 release, the tools available in the Aerospace pull-down menu are migrated to general pages and/or removed if the use case is already covered in other tools. This is valid in HyperWorks only.
- In the 2021.2 release, all menus available under the Beams/Checks/Results cascade were removed from the pull-down.
- Beams
- Section Cut (Create and Review) were removed (available in the search bar for 2021.2) as covered by Section Property context.
- Split 1D Elems is removed (available in the search bar for 2021.2).
- Beamsection from CSV and Beam Update are migrated as a menu under the 1D Mesh group.
- Beam review is deprecated as already superseded by 1D Mesh review tool.
- Replace Orientation Nodes By Cord is covered in this release in
the 1D Mesh Orient tool.
- Checks
- List 1D elements Elems from Orientation Nodes is deprecated as
covered by Idle mode:
- Select the node and then switch to elements finds 1D elements using nodes as orientation node.
- Nastran Checks are available as Validate in the Model
Checker.
- Global Model Validation and Model reduction are special checks that can be loaded in the Model Checker directly.
- CFAST Validation is available in the search bar only.
Figure 3.
- Results
- File loader and derived loadcase are migrated to the regular Results Browser in the Post ribbon.
- Free body tools have been migrated to the Post ribbon.
- Results Query and MinMax/Ranking/Envelope have a new entry point in the Post ribbon (Tools).
- The Matrix Browser has a new entry point in the Post ribbon.
Figure 4.
- Spatial ID Manager
- The older Spatial Renumbering tool is deprecated. The feature can now be
accessed from the Assembly ribbon.
Figure 5.
