Edit the Mesh Type/Mapping Method and Define Free Surfaces
Use the Solid Map: Face Edit tool to edit the mesh type and mapping method of individual target/source surfaces. You can also define free or unmapped surfaces by selecting points.
Edit the Parameter and Criteria files and define mesh controls using the Mesh Controls Browser.
1D mesh that allows accurate testing of connectors, such as bolts, and similar rod-like or bar-like objects that can be modeled as a simple line for FEA purposes.
A surface mesh or "shell mesh" represents model parts that are relatively two-dimensional, such as sheet metal or a hollow plastic cowl or case.
Volume mesh or "solid meshing" uses three-dimensional elements to represent fully 3D objects, such as solid parts or sheets of material that have enough thickness and surface variety that solid meshing makes more sense than 2D shell meshing.
Supported 3D elements.
Use the Tetra tool to fill an enclosed volume with first order or second order tetrahedral elements.
Use the Hex tool to create and edit hex meshes.
Use the Solid Map tool to create and edit a mesh of solid elements in a solid geometric volume.
Use the Solid Map: Create tool to 3D mesh on mappable solids.
Use the Solid Map: Density tool to edit element density and size along source/target surface edges.
Use the Solid Map: Biasing tool to apply linear, exponential, or bellcurve biasing to individual edges of a target/source surface, and edit the elements size distribution.
Use the Thin Solids tool to create 3D mesh on thin solids. The mesh is created by first generating a 2D mesh on a selected set of source faces, and then extruding this mesh to generate solid hexa or wedge elements.
Acoustic Cavity meshing generates a fluid volume mesh used to calculate the acoustic modes (or standing waves) inside the air spaces of a vehicle or similarly enclosed structural model.
to define surface mesh options.
If the Auto update option is tuned off, first click Update to modify the 2D mesh.
