Relocate Nodes/Elements to their Initial Locations
Use the Edit Elements: Origin tool to relocate moved nodes and elements to associated geometry.
  1. From the Elements ribbon, click the Edit Elements > Origin tool.
  2. Select nodes or elements.
  3. Click on the guide bar.
    Note:
    • If nodes are moved within the surface/edge, the current position of the node is updated as the origin. Therefore, nodes are not moved back to their initial locations upon using the Origin tool.
    • If nodes are moved away from the surface/edge, nodes are always brought back to the initial locations upon using the Origin tool, even after multiple node movements.
      Figure 3.
