HyperWorks
HyperWorks
2021.2
  1. Home
  2. Interface with External Products
  3. HyperView Solver Interfacing
    Supported solvers in HyperView.
  4. Interfacing with Nastran
    Overview of how the HyperView applications interface with the Nastran solver.
  5. Complex Results
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Model Build and Assembly
  • Sketching
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Validate
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Squeak and Rattle Director
  • Geomechanics Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Text Files
  • Tabulate Results
  • Publishing and Reporting
Index
HyperWorks
2021.2
HyperWorks
  • What's New
  • Get Started
  • Video Tutorials
    • Change Solver Interfaces
      Load a different solver interface in HyperWorks.
    • HyperMesh Solver Interfacing
      Supported solvers in HyperMesh.
    • HyperView Solver Interfacing
      • Solver Results Supported in HyperView
        When you select a model or results file, HyperView automatically detects the file type and selects the proper reader to import the data.
      • Interfacing with Abaqus
        Overview of how the HyperView applications interface with the Abaqus solver.
      • Interfacing with ADAMS
        Overview of how the HyperView applications interface with the ADAMS solver.
      • Interfacing with ADVC
        Overview of how the HyperView applications interface with the ADVC solver.
      • Interfacing with Animator DB
        Overview of how the HyperView applications interface with Animator DB.
      • Interfacing with ANSYS
        Overview of how the HyperView applications interface with the ANSYS solver.
      • Interfacing with I-DEAS
        Overview of how the HyperView applications interface with the I-DEAS solver.
      • Interfacing with LS-DYNA
        Overview of how the HyperView applications interface with the LS-DYNA solver.
      • Interfacing with LS-NIKE3D
        Overview of how the HyperView applications interface with the LS-NIKE3D solver.
      • Interfacing with MADYMO
        Overview of how the HyperView applications interface with the MADYMO solver.
      • Interfacing with MARC
        Overview of how the HyperView applications interface with the MARC solver.
      • Interfacing with Moldflow
        Overview of how the HyperView applications interface with Moldflow.
      • Interfacing with Nastran
        • Supported Nastran Results in HyperView
          HyperView supports Nastran FEMZIP, OP2, XDB and H5 result file formats.
        • Loading Nastran Models and Results in HyperView
          Animation files are loaded using the Load Model panel.
        • Using the Contour, Tensor Plot, and Vector Plot Panels for Nastran Results
          The options on the Contour, Tensor Plot, and Vector Plot panels in HyperView are based on the Nastran and OptiStruct solvers.
        • Complex Results
        • Stress Transformation and Averaging
          In HyperView you can transform stress results to any coordinate system following certain system projection rules. You also can calculate the stress average using various averaging schemes, and have control over which stresses should be averaged.
        • Nastran Model Input Reader
        • Nastran XDB Results Reader
          The Nastran XDB Results Reader can be customized by using the Reader Options dialog in the Load Model panel.
        • Element Forces (Tensor Plot)
          2D element forces and moments are supported as tensors and can be plotted using the Tensor panel in HyperView.
        • Element Forces (Vector Plot)
          1D element forces and moments are supported as vectors and can be plotted using the Vector panel in HyperView.
      • Interfacing with OptiStruct
        Overview of how the HyperView applications interface with the OptiStruct solver.
      • Interfacing with nSOFT
        Overview of the HyperViewnSOFT interface.
      • Interfacing with PAM-CRASH 2G
        Overview of how the HyperView applications interface with the PAM-CRASH 2G solver.
      • Interfacing with Radioss
        Overview of how the HyperView applications interface with the Radioss solver.
      • CFD AcuSolve Reader
        AcuSolve results for steady state, transient and moving/deforming mesh analyses can be imported and post-processed using the AcuSolve Reader (*.log) in HyperView.
      • CFD Ensight Reader
        Load post-processing files using the Load Model panel.
    • HyperGraph Solver Interfacing
      Supported solvers in HyperGraph.
    • MotionView Solver Interfacing
      Solvers and translators supported in MotionView.
  • Sketching
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Validate
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
View All Altair Simulation Help
HyperWorks
HyperWorks
2021.2
  1. Home
  5. Complex Results
  • What's New
  • Get Started
  • Video Tutorials
  • Sketching
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Validate
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
Index
Complex Results
For detailed information about complex results, refer to Complex Results.
