HyperWorks
HyperWorks
2021.2
  1. Home
  2. Interface with External Products
  3. HyperView Solver Interfacing
    Supported solvers in HyperView.
  4. Interfacing with Abaqus
    Overview of how the HyperView applications interface with the Abaqus solver.
  5. Result Data from ODB
    HyperView supports both field and history data from the Abaqus ODB file.
  6. Element Results
  7. Complex Results
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Model Build and Assembly
  • Sketching
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Validate
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Squeak and Rattle Director
  • Geomechanics Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Text Files
  • Tabulate Results
  • Publishing and Reporting
Index
HyperWorks
2021.2
HyperWorks
  • What's New
  • Get Started
  • Video Tutorials
    • Change Solver Interfaces
      Load a different solver interface in HyperWorks.
    • HyperMesh Solver Interfacing
      Supported solvers in HyperMesh.
    • HyperView Solver Interfacing
      • Solver Results Supported in HyperView
        When you select a model or results file, HyperView automatically detects the file type and selects the proper reader to import the data.
      • Interfacing with Abaqus
        • Multiple ODB Version Support
          The ODB Reader supports multiple versions of Abaqus ODB results files.
        • Parts and Instances in the ODB File
          The ODB data structure is designed as parts and instances.
        • Result Data from ODB
          • Customizing the ODB Reader
            The HyperView ODB reader can be customized by using the Reader Options dialog in the Load Model panel.
          • Contour Panel for Abaqus Results
            The Contour panel in HyperView has contour options for FEA results.
          • Element Results
            • Tensor Results
              In general, HyperView supports tensor results in global, analysis, and elemental (Nastran-like) systems.
            • Results at Position - Integration Points
              Default option in Abaqus. If the ODB file contains only integration point results, the ODB reader in HyperView extrapolates the results to the element corner nodes in addition to the results for the integration points.
            • Complex Results
            • Surface Results
              HyperView supports surface results that are available in ODB for shell and solid element.
        • Model Data
          In the Animation client, either the Abaqus INP or ODB file can be loaded for model data.
      • Interfacing with ADAMS
        Overview of how the HyperView applications interface with the ADAMS solver.
      • Interfacing with ADVC
        Overview of how the HyperView applications interface with the ADVC solver.
      • Interfacing with Animator DB
        Overview of how the HyperView applications interface with Animator DB.
      • Interfacing with ANSYS
        Overview of how the HyperView applications interface with the ANSYS solver.
      • Interfacing with I-DEAS
        Overview of how the HyperView applications interface with the I-DEAS solver.
      • Interfacing with LS-DYNA
        Overview of how the HyperView applications interface with the LS-DYNA solver.
      • Interfacing with LS-NIKE3D
        Overview of how the HyperView applications interface with the LS-NIKE3D solver.
      • Interfacing with MADYMO
        Overview of how the HyperView applications interface with the MADYMO solver.
      • Interfacing with MARC
        Overview of how the HyperView applications interface with the MARC solver.
      • Interfacing with Moldflow
        Overview of how the HyperView applications interface with Moldflow.
      • Interfacing with Nastran
        Overview of how the HyperView applications interface with the Nastran solver.
      • Interfacing with OptiStruct
        Overview of how the HyperView applications interface with the OptiStruct solver.
      • Interfacing with nSOFT
        Overview of the HyperViewnSOFT interface.
      • Interfacing with PAM-CRASH 2G
        Overview of how the HyperView applications interface with the PAM-CRASH 2G solver.
      • Interfacing with Radioss
        Overview of how the HyperView applications interface with the Radioss solver.
      • CFD AcuSolve Reader
        AcuSolve results for steady state, transient and moving/deforming mesh analyses can be imported and post-processed using the AcuSolve Reader (*.log) in HyperView.
      • CFD Ensight Reader
        Load post-processing files using the Load Model panel.
    • HyperGraph Solver Interfacing
      Supported solvers in HyperGraph.
    • MotionView Solver Interfacing
      Solvers and translators supported in MotionView.
  • Sketching
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Validate
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
View All Altair Simulation Help
HyperWorks
HyperWorks
2021.2
  1. Home
  6. Element Results
  7. Complex Results
  • What's New
  • Get Started
  • Video Tutorials
  • Sketching
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Validate
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
Index
Complex Results
For detailed information about complex results, refer to Complex Results.
