2021.2
Entities used to set up optimization problems.
Collectors are named organizational containers for collected entities. Collected entities are nameless entities which must reside within one, and only one, collector. Collected entities are mutually exclusive to a collector.
Entities which are given a name but are not collected or organized into containers.
Entities used for morphing the shape of FE model.
Design variable entities define and store design variables for optimization problems.
Design variable link entities define links between design variables for optimization problems.
Design variable property relationship entities define relationships between design variables and properties for optimization problems.
Discrete design variable entities define and store discrete design variables for optimization problems.
Optimization response entities define and store model responses for optimization problems.
Optimization constraint entities define and store constraints on model responses for optimization problems.
Optimization equation entities define and store equations for optimization problems.
Optimization table entry entities define and store table data for optimization problems.
Objective entities define and store an objective for an optimization problem.
Objective reference entities define and store objective references for an optimization problem.
Optimization constraint screening entities define and store constraint screening data for optimization problems.
Optimization control entities define and store controls for optimization problem run.
Control card entities create solver control cards such as results file I/O options, CPU and memory limits, and others.
Undefined entities are entities that will not be written to the solver deck.
The encryption of solver entities is used to translate entity data into an undisclosed language.
Element property and material assignment rules are based on the current user profile (solver interface).
Supported cards organized by solver.
View All Altair Simulation Help
