Change the Tensor Color by Direction
From the Plot tools, click the Tensor tool.
- From the Tensor panel, click the Display tab (located in the middle of the panel).
Select Direction from the Color by drop-down menu.
The tensor is displayed with the colors defined by the buttons. The buttons are enabled and the default colors for the tensor are:
- Red for P1 (Major) or XX
- Green for P2 (Mid) or YY
- Blue for P3 (Minor) or ZZ
- Yellow for XY
- Light blue for YZ
- Purple for ZX
Click the color box and select a different color from the color palette.
The color for the tensor is changed.
