Add a Note
  1. From the Annotate tools, click the Notes tool.
  2. To attach the note to a specific entity type, use the guide bar drop-down menu to select the entity type (Nodes, Elements, Components, or Systems).
  3. Click on the entity where you would like to create a note or click in an empty space to create a free-floating note.
  4. Drag and drop the note that you just created to place it anywhere in the modeling window.
