Extract and Linearize
Starting in version 2021, the Stress Linearization tool has been renamed as Extract-Linearize and will support both the Extract Data and Stress Linearization methods.
Extract Data
Extract any contour data at various points along a path defined on solid elements.
Extract stress data at various points along a path (also known as stress classification line) defined on solid elements and then calculate linearized stresses based on these extracted values.
Both methods use paths defined on solid elements and therefore, the same path can be used for either method. However, there are some differences in the extraction and calculation part as shown in the table below:
  Extract Data Stress Linearization
Purpose Extract any contoured data along a path Extract stress data along a path and calculate linearized stresses
Resolved in System Contour Resolved in System Transformed to a path based local system
Calculation Data Type Displayed Contour Base Stress Tensor or Displayed Stress Contour
Plot Options Distance along path versus Extracted values (single curve) Distance along path versus Extracted and Linearized values (multiple curves)
To understand these differences and learn more about how each method works, please refer to the relevant topics below.
